Mini line array
Emil Elmqvist
Mini line array
Jag tänkte kolla om någon här kan bedöma hur mycket man får ut från 2 st L-array/1000 och text 3 st 18" basar som dom nedan? Självklart är det otroligt svårt att uppskatta beroende på lokal mm men i alla fall någon stans mellan tummen och pekfingret.
Någon som testat dessa ?
IMG-Stageline "L-array/1000"
System compact line array
Bass speaker 2 x 20cm (8")
Midrange 8 x 10cm (4")
Tweeter 4 x magnetostatic speaker
Power rating
Max. power 1,000WMAX
Power rating 700WRMS (350W + 350W)
General Information
Frequency range 50-25,000Hz
SPL (1W/1m) 98dB
Max. rated SPL 121dB
Radiation angle hor. 120°, vert. 30°-90° var.
Connections
Inputs
Line
XLR jack, 1-10V/30k ohm
Speaker (at the top)
NEUTRIK SPEAKON
Power supply
PowerCon
Outputs
Line
XLR par. out
Speaker (at the bass speaker)
NEUTRIK SPEAKON
NEUTRIK SPEAKON par. out
Admiss. ambient temp. 0-40 °C
Amplifier section
S/N ratio 80dB
THD <0.1%
Power supply 230˜/50Hz/1,400VA
Dimensions array 495x850x610mm
Weight 51kg
Special feature interface for DSP programming:
USB, RS-232, RS-485 IN & OUT,
supplied with software which is both
extremely easy to use and very efficient
MEGA-118SUB (img Stageline)
System bass-reflex
Bass speaker 46cm (18", FTR18-4080HDX)
Tweeter -
Power capabilities
Music power 2,000WMAX
Power rating 1,000WRMS
General information
Impedance 8 ohm
Frequency range 30-200Hz
SPL (1W/1m) 97dB
Max. rated SPL 126dB
Dimensions 700x570x590mm
Inputs 1 x NEUTRIK SPEAKON
Outputs 1 x NEUTRIK SPEAKON
Weight 47kg
Allt på Monacor
http://shop.monacor.se/servlet/us_pyra? ... nguest&p=H" onclick="window.open(this.href);return false;
Power rating
General Information
SPL (1W/1m) 98dB
Connections
Inputs
Line
NEUTRIK SPEAKON
Power supply
PowerCon
Outputs
Line
XLR par. out
NEUTRIK SPEAKON
Amplifier section
S/N ratio 80dB
THD <0.1%
Weight 51kg
System bass-reflex
Tweeter -
Power capabilities
General information
Impedance 8 ohm
SPL (1W/1m) 97dB
Weight 47kg
Allt på Monacor
- Bilagor
- image.jpg (19.66 KiB) Visad 12663 gånger
- image.jpg (26.6 KiB) Visad 12663 gånger
Elmqvist Entertainment
Sundsvall
072-183 19 41
Sundsvall
072-183 19 41
Magnus Gustafsson
Re: Mini line array
Med så kort längd på arrayen så får du inte någon "line array-effekt".
Basarna skulle jag hellre ha på golvet där de får stöd från golv, anläggningen
blir dessutom smidigare att rigga.
Jag har inte hört detta system men jag skulle hellre satsa på ett begagnat,
mer konventionellt system med två toppar och två basar.
Kanske inte svar på din fråga egentligen.
_________________
T b a
T b a
Re: Mini line array
Jag har inte provat dem, bara läst nu från produktlänken.
Men om det är inför eventuellt köp du funderar så ville jag bara flika in att hur mycket "line" och "array" man än vill benämna produkten så går det inte att betrakta som en linjekälla hur mycket man än vill, utan för den absoluta huvuddelen av frekvensområdet är det en punktkälla med variabel vertikalspridning. Så det är snarare bland punktkällor som du hittar tänkbara alternativ.
Magnus Gustafsson
Re: Mini line array
Ser att jag läst lite fel.
Trodde att det var 2x8" i varje liten låda och 1x18" i den stora ovanför.
Det är alltså 2x4" + diskant i de små lådorna och 2x8" i den större ovanpå.
18"-basarna tillkommer utöver det.
_________________
T b a
T b a
Emil Elmqvist
Re: Mini line array
Självklart ser jag inte detta som en ersättare av ett "riktigt" Line Array utan mer som en ersättare för som ovan nämnd konventionellt system med tex 2 toppar och 2 basar. Har hört en del bra om systemet från ett flertal personer och tycker att det verkar intressant. Dessutom det faktum att det går att rigga med dansbandspinne från Arrayets baslåda med tillbehör från monacor.
Sundsvall
072-183 19 41
Sundsvall
072-183 19 41
Re: Mini line array
men n det är väl max 4 lådor hängandes i det systemet eller??
Emil Elmqvist
Re: Mini line array
Jag vet att man kan hänga minst 4 system (totalt 20 lådor) om man kollar i manualen.
http://www.monacor.dk/produkter/?jumpur ... 6fe38b4cf9" onclick="window.open(this.href);return false;
Sundsvall
072-183 19 41
Sundsvall
072-183 19 41
Re: Mini line array
ok ja me då så då blir det ju lite bättre
Emil Elmqvist
Re: Mini line array
Ja precis, finns det någon som kan göra en uppskattning på vad detta kan klara ?
Sundsvall
072-183 19 41
Sundsvall
072-183 19 41
Magnus Gustafsson
Re: Mini line array
Om du vänder på frågan. Vad vill du kunna använda lådorna till? Dvs vilken typ av evenemang, storlek på lokal etc.
_________________
T b a
T b a
Emil Elmqvist
Re: Mini line array
Jadu. Lite allt möjligt vore väl det rätta uttrycket. Nä men jag har tänkt att använda dom till mycket små tillställningar typ bara ett "system" utan basar riggat på dansbandspinne/stativ till egna akustiska spelningar (en akustisk gitarr och 2-3 sång)
men även till lite större grejer. Det är just att se hur mycket det klarar jag behöver hjälp med. Att få en bild av begränsningarna.
Det är just det här med att systemet går att skala av som gör mej sugen på det.
Sundsvall
072-183 19 41
Sundsvall
072-183 19 41
Re: Mini line array
Ni som använder line array-högtalare på det här sättet,
- Använder ni prediktionsprogramvaran varje gång eller kör ni samma vinklar varje gång ni kör "line array on a stick"?
- Tar ni proportionellt betalt ? Det krävs ju minst 3 lådor per sida och en bra line array-låda kostar ju ofta aningen mer än den point source-låda som hade gjort jobbet.
- Märker ni någon avsaknad av lågmid ? Systemen är ju ofta avstämda för fler lådor per sida.
- Vad är huvudsyftet till att välja detta framför en bra point source-låda ?
Emil Elmqvist
Re: Mini line array
Idag var jag och lyssnade på detta system i en studio i Sundsvall och blir riktigt förvånad. Visserligen trodde jag inte att de skulle låta dåligt men det här var enligt mej något helt annat än dåligt. Visst det lät det inte världsklass men riktigt bra och kunde spela högt med endast de basar som var med (2x8"). Kändes perfekt för det ändamål jag ska ha de till så jag slog till.Så ikväll har grannarna fått höra lite musik ... Nu är det bara att leta ett par basar att komplettera med när det behövs
Sundsvall
072-183 19 41
Sundsvall
072-183 19 41
Re: Mini line array
kul resentioner uppskattas
Re: Mini line array
Hur många lådor blev det ?
Jag blir lite rädd när jag ser bilden, finns det verkligen vevstativ som klarar att lyfta en line array ?
Emil Elmqvist
Re: Mini line array
Det blev 12 "toppar" 3 "basar" till att börja med. Ska beställa några lösa basar till det då systemets basar endast är 2x8".
Haha, ja jag förstår oron med tanke på bilden där ena stativet till och med ser snett ut. Grejen är att topparna inte väger mycket alls. Självklart så skulle jag aldrig rigga det såhär på "riktigt" utan det var bara ett snabbtest här hemma
Sundsvall
072-183 19 41
Sundsvall
072-183 19 41
