Mixern har stått nerpackad i typ 20 år.
Testad av mig.... Behöver lite kärlek. troligen bara lite rengöring och kontaktspray.
Muteknappar låser sig etc. De kanaler som inte har problem med knapparna funkar OK!
Låter som den ska .
Eurorack MX2642A 26-Input 4-Bus Mixer
Ultra low-noise 26-channel 4-bus mixer with assignable subgroups
Extremely high headroom - offering more dynamic range
4 assignable subgroups for multitracking / mixing
8 mono input channels with insert points and direct outputs
Ultra low-noise discrete mic preamps with +48 V phantom power
4 stereo input channels
4 additional multifunctional stereo line inputs with Aux sends
6 Aux Sends with Aux 1 and 2 switchable pre-/post fader
Ultra-musical 4-band EQ on stereo channels
Semi-parametric midrange EQ and switchable Low-Cut filter on mono channels
Balanced inputs and outputs
Solo-In-Place and Pre-Fader-Listen function
Separate mix and monitor / headphones outputs with insert points on mix outputs
2-track inputs assignable to main mix or monitor / headphones outputs
High-quality 60 mm laser-trimmed faders and sealed potentiometers
State-of-the-art 4580 ICs and high-quality components ensure crystal-clear audio performance and excellent noise figures
Moveable connector panel for table-top or rack mounting
High-quality components and exceptionally rugged construction ensure long life
Designed and engineered in Germany
Tung 11kg
Endast avhämtning Västberga Stockholm.
Pris 1 000 kr
Lagerrens ! Behringer MX2642 26/4/2
Jerry Jansson
