Mccrypt 30w moving head
Kristian Ranta
Presentation: Hobby PA, Billjud, ljudintresserad nybörjare.
Inlägg av Kristian Ranta »
Nyskick, säljes med tillhörande kartong.
Kan provvisas i Umeå.
Använd kanske 4-5 kvällar.
3500:-
(Säljs även som Beamz MHL 30 Spot men denna har snyggare gobos)
FIlm på färger & Gobos:
http://www.youtube.com/watch?v=EKXSAgSO9Qc" onclick="window.open(this.href);return false;
A compact 10-channel DMX moving head with a powerful 30W LED. The LED light output is impressive. Nice effects of the rotating gobos. Variable electronic strobe and dimmer. The moving head can be controlled via 10 DMX channels or via sound activation. Ideal for use in discotheques, bars, large halls, etc.
10-channel DMX
30W LED
Pan 585 deg., 225 deg. Tilt-High resolution
6 Rotating gobos + open
7 colors + open
Variable electronic strobe and dimmer (0-100%)
DMX, master / slave and sound activated
Reset to default
Selectable pan / tilt direction
Manual Focus-adjustment
Consumption: 80W
Weight: 7.3 kg
No. of colours: 7+open
No. of gobos: 6+open
Head movement:Pan: 585 °
Light intensity: 4100LUX
Dimensions: 265 x 260 x 320mm
Head movement:Tilt: 225 °
Power Supply: 220-240Vac/50Hz
Beam angle: 12 °
DMX channels: 10
No. of LEDs: 1 (30W / >50.000hrs)
Kristian Ranta
Re: Mccrypt 30w moving head
2500:-
Kan skickas eller hämtas öga mot öga här i Umeå.
