två aktiva arrays L-RAY/1000 NYA
Jocke Källgren
Presentation: DJ som älskar ljud och ljus, snackar inte utan gör det.
Inlägg av Jocke Källgren »
har två st aldrig använda kommer aldrig använda dessa heller.
säljes till ett bra pris!!!
Professional State-of-the-Art PA Technology Now Also Available at a Compact Size:
The active speaker arrays L-RAY/1000 and L-RAY/1000WS from IMG Stage Line impress by a perfect sound with professional adjusting facilities, the advantages of the radiation typical of array, a high-quality workmanship and an amazing level stability.
Professional PA speaker array (controlled by DSP software), active, 1,000WMAX, 700WRMS (350W+350W)
A compact array of high power capability with 4 mid-high range speaker units and a dual bass module, each section with its own 350WRMS power amplifier and controlling software (the configuration of the system is supported by a PC, but it operates as a stand-alone unit!). Supplied with extensive and variable equipment for suspended mounting systems (Flyware), clusters with up to 4 x L-RAY/1000 are possible. The mid-high range systems are each equipped with 2 x 10cm (4") high-performance speakers and a magnetostatic speaker for a perfect reproduction rich in detail. The dynamic characteristics are absolutely convincing, at the same time the tonality at the basic setting is very pleasant. Despite its compact size, the bass module with two 20cm (8") bass speakers provides an amazingly deep bass reproduction and a high level stability which is only possible by using special bass speakers of very high power capability and the extensive optimisation of the DSP.
The software allows the following adjustments (min. system requirement is a Windows PC only, WIN98 or higher, with CD drive and interface):
Parametric equalizer (6 bands)
Filters (high-pass or low-pass up to 36dB/oct. with various characteristics)
Level
Compression and limiting
Delay
Up to 10 L-RAY systems can be addressed via one RS-485 data bus.
On delivery, the software of the system is matched to a perfect base linearity and can be used immediately! Otherwise, the software adjustments are extremely easy to do and sound engineers can even operate it intuitively.
Beside the system connection cables (NEUTRIK SPEAKON), adjusting elements for the alignment of the system and solid eyelet bolts for suspension are also supplied with the unit. Connection to the mains is done via a PowerCon® jack (e.g. with mains cable AAC-115P).
The stable wooden cabinets feature grilles which are protected against ball rebound and a robust structured coating.
The L-RAY/1000 systems are a very high-quality solution for every PA application where both perfect tonality and perfect radiation across the room are required. The advantages of the system particularly take effect with fixed installations in clubs and discotheques as well as mobile stage applications of medium size. For larger PA applications, the use of several L-RAY in a cluster is recommended.
Xound 01/2009
"The L-RAY/1000 gives a convincing performance. The system provides a detailed reproduction of absolutely low distortion up to the highest frequencies, even at high volume levels. A real pleasure with perfect speech intelligibility. Excellent price-performance ratio!"
System compact line array
Bass speaker 2 x 20cm (8")
Midrange 8 x 10cm (4")
Tweeter 4 x magnetostatic speaker
Power rating
Max. power 1,000WMAX
Power rating 700WRMS (350W + 350W)
General Information
Frequency range 50-25,000Hz
SPL (1W/1m) 98dB
Max. rated SPL 121dB
Radiation angle hor. 120°, vert. 30°-90° var.
Connections
Inputs
Line
XLR jack, 1-10V/30k ohm
Speaker (at the top)
NEUTRIK SPEAKON
Power supply
PowerCon
Outputs
Line
XLR par. out
Speaker (at the bass speaker)
NEUTRIK SPEAKON
NEUTRIK SPEAKON par. out
Admiss. ambient temp. 0-40 °C
Amplifier section
S/N ratio 80dB
THD <0.1%
Power supply 230˜/50Hz/1,400VA
Dimensions array 495x850x610mm
Weight 51kg
Special feature interface for DSP programming:
USB, RS-232, RS-485 IN & OUT,
Re: två aktiva arrays L-RAY/1000 NYA
lät dom inge bra?
Jocke Källgren
Jo men det är ändrade planer.
jag har länge undrat hur dessa låter
Jocke Källgren
Ja har lyssnat på dessa när jag köpte dessa, men dessa är inte ens upplockade ur kartongen.
De väger ca 56kg, så det är ju inget du tar under armen och går! :D
