NovaStar VX1000 *Ny skick* OBS SÅLD!!
Walter Andersson
Inlägg av Walter Andersson »
En demo körd VX1000 i nyskick se beskrivning nedan.
Pris 15 500sek inklusive moms
Best Regards/Vänliga hälsningar
Walter Andersson
Liveteknik AB
Kastanjevägen 7
371 60 Karlskrona
+46 (0)708 317142
DESCRIPTION OF THE
NovaStar VX1000
The VX1000 is the new all-in-one controller from NovaStar that integrates video processing and video controlling in one device. It has 10 Ethernet ports and supports different working modes (video controller, fibre converter, bypass mode). A single unit can manage up to 6.5 million pixels.
HARDWARE FEATURES:
Inputs:
2x HDMI 1.4 (max. 3840×1080@60Hz / max.3840×2160@30Hz)
2x DVI ((HDMI 1.4)max. 3840×1080@60Hz / max.3840×2160@30Hz)
1x 3G-SDI (max. 1920×1080@60Hz)
Outputs:
10x LED-Out (RJ45)
1x HDMI 1.3 Out
1x DVI Loop
2x OPT-Out (10G)
further features:
V-Can Support
Genlock
Supports up to 3x layers
Memory for 10 presets
Cascading via USB possible
Display configuration without computer possible
Control via USB or LAN
