Två helt nya blackmagic 2110 ip converter i oöppnade förpackningar.
Pris 10 000sek inklusive moms
Best Regards/Vänliga hälsningar
Walter Andersson
Liveteknik AB
Kastanjevägen 7
371 60 Karlskrona
+46 (0)708 317142
”The new Blackmagic 2110 IP Converter 3x3G lets you convert 3 separate 3G-SDI devices to 2110 IP video systems. That’s because its 10G Ethernet connection can handle 3 separate video channels at the same time. Plus each channel has independent SDI inputs and SDI outputs, so you could even connect to 6 completely different SDI devices! All 3G-SDI inputs feature loop outputs so you can install the converter in line within existing SDI systems. There's also a reference output, timed to the 2110 PTP clock! Blackmagic 2110 IP Converter 3x3G includes an elegant front panel with a color LCD for monitoring, menus and diagnostics”
SÅLDA ! 2x blackmagic 2110 ip converter
Walter Andersson
Walter Andersson
