Martin MiniMAC Maestro II titanium
Johan Nilsson
Presentation: Jobbar på hobbybasis med öppna källkodsprojekt för ljusstyrning. https://gobo.ws
Inlägg av Johan Nilsson »
En begagnad Martin MiniMAC Maestro II säljes.
Mindre moving head för att projektera logotyper etc.
Med motoriserad fokus.
Tar gobos i E-storlek.
Titanium finish.
Två nya Philips CDM-SA/T 150 W ljuskällor ingår.
Pris: 995:- (säljes privat)
För mer information se:
http://www.martin.com/en-us/product-det ... ID=PROD136
Designed for high quality projection of patterns, images, logos, text and messages, the MiniMAC Maestro is an
ultra-compact automated moving head useful in a variety of environments.
The MiniMAC Maestro features a top quality optical system, which together with the long life (6000H) 150W CDM-SA/T discharge lamp,
ensures a perfect projection of up to 4 images.
The 4 slots for gobos are all easy interchangeable and can be rotated or indexed in any position.
Useful in retail environments, exhibitions, restaurants and hotels, any image can be projected onto walls, ceilings, floors, anywhere desired.
A precise remote focus keeps the projection razor-sharp. It is possible to insert a color flag, for color change, and
the light can be instantly blacked out via the remote controlled shutter.
The MiniMAC Maestro offers precise movement in a range of 540° of pan by 270° of tilt. Its small size and wide range of movement make it ideal for even the
smallest settings and ceiling heights.
Fixture settings are controlled via a 3-digit control panel and a switch-selectable, power supply setting gives full flexibility.
The MiniMAC Maestro offers all the power of a bright 150-watt discharge source (included) and may be operated via DMX controllers or
via the on- board memory for stand-alone programming. The stand alone programming can be done via the display or via
an infrared remote control (optional). Multiple MiniMAC Maestros can run synchronized in master/slave configuration.
The MiniMAC Maestro is available in white or titanium finishes, so that environments from restaurants to shops can easily and
discretely integrate its many features.
* 150W CDM discharge lamp
* 19° focused beam angle
* 4 replaceable pattern slots
* Convenient ¼ turn fasteners
* Dichroic color slot
* DMX (channels: 6/8/9/11), master/slave, on board, remote controllable
* High quality 5-element focus
* Modular Construction for easy maintenance
* PAN/TILT range of 540°/270°
* Gobo indexing resolution: 8- and 16-bit
* Pan/tilt resolution: 8- and 16-bit
* Separate shutter
