Behöver byta ut 2 element i ett gammalt dth-system.
Någon som har 2st 1505-dt 8 ohm liggandes?
Eller några element med likvärdig spec?
Bifogar spec också:
- Impedance: 8 Ohms
- Power capacity: 1400 W Peak, 700 W Program, 350 W Continuous
- Sensitivity: 97.9 dB / 1 W 1 m
- Usable freq. range: 40 Hz ~ 2 kHz
- Cone: Kevlar impregnated cellulose
- Voice coil diameter: 4.0 inch / 100 mm
- Voice coil material: Aluminum ribbon wire, Polyimide-impregnated fiberglass former, Nomex(r) stiffener, Solderless diffusion welded OFHC copper leads
- Packed Weight: 19 lbs.
- Packed Width: 18.25 in.
- Packed Depth: 17.25 in.
- Packed Height: 6.25 in.
2st peavey-element 1505-dt 8 ohm
Emil EBP Brolin
Emil EBP Brolin
Re: 2st peavey-element 1505-dt 8 ohm
Problemet löst!
