Enkel Mixer 8-16ch köpes!
Kristian Nilsson
Inlägg av Kristian Nilsson »
Jag söker efter en enkel, billig livemixer i fint skick, minst 8 mick-kanaler, gärna 2-4 aux.
Någon som har något liggandes?
Alla förslag mottages, i detta fallet även Behringer etc =)
Även tips på vad ni hade valt mottages tacksamt, även om ni inte har någon att sälja.
Mvh
Kristian
Re: Enkel Mixer 8-16ch köpes!
Inlägg av Magnus Gustafsson »
Har en Phonic 1805x med inbyggd effektdel.
1.200kr + moms inkl case.
http://www.zzounds.com/item--PHOMM1805X" onclick="window.open(this.href);return false;
Inputs:
-- Balanced mono mic/line channels: 6
-- Balanced stereo line channels: 4
-- 2T input: 1
-- Aux returns: 2 stereo
Outputs:
-- Main L/R stereo: TRS, balanced
-- Main mono: TRS, balanced
-- Aux sends: 2, TRS, balanced
-- Submaster: 2, TRS, balanced
-- Phones: 1
-- Control RM: TRS, unbalanced
Channel strips:
-- 10 total
-- Aux controls: 2
-- Pan/balance control: yes
-- Channel mute: yes
-- Channel solo (PFL) with metering: yes
-- LED indicators: on, peak
-- Bus assign switches: 1/2, L/R
-- Volume controls: 60mm faders
-- MS matrix: 3
-- Inserts: 6
Master section:
-- Aux send masters: 2
-- Master aux send solo (AFL): 2
-- Stereo aux returns (efx return): 2
-- Global aux return (efx return) solo (PFL): yes
-- Phones/control RM level control: yes
-- Phones/control RM source switching: yes
-- Faders: main, group, mono
Metering:
-- MS/ST
-- Number of channels: 2
-- Segments: 13
Phantom power supply: +48VDC
-- Switches: master + 6
Built-in effect processor: 255 programs
Built-in graphic EQ: stereo, 7-band
Noise 20Hz to 20KHz bandwidth, line inputs to main L/R outputs, all channels assigned, panned L/R:
-- Master @ unity, channel fader down: -89dBu
-- Master @ unity, channel fader @ unity: -86dBu
-- S/N ratio, ref to +4: >90dB
THD any output, 1KHz @ +14dBu, 20Hz to 20KHz, channel inputs: <0.005%
CMRR 1 KHz @ -60dBu, gain at maximum: 80dB
Crosstalk 1KHz @ 0dBu, 20Hz to 20KHz bandwidth, channel in to main L/R outputs:
-- Channel fader down, other channels at unity: <-86dB
-- Channel muted, other channels at unity: <-85dB
Frequency response:
-- 20Hz - 20KHz (gain min.): +/- 1dB
-- 20Hz - 20KHz (gain max.): +/- 2dB
Maximum Levels:
-- Mic preamp input: +10dBu
-- All other inputs: +22dBu
-- Balanced outputs: +28dBu
-- Unbalanced outputs: +22dBu
Impedance:
-- Mic preamp input: 2 kilohms
-- All other inputs (except inserts): 10 kilohms
-- RCA 2T outputs: 1.1 kilohm
-- All other outputs: balanced: 440 ohms, unbalanced: 220 ohms
Equalization:
-- 3-band, +/-15dB
-- Low EQ: 80Hz
-- Swept mid: EQ 100~8KHz
-- Hi EQ: 12KHz
-- Low cut filter: 75Hz (-18dB/oct)
Microphone preamp E.I.N. (150 ohms terminated, max gain): <129.5dBm
Power consumption: 40 watts
Weight: 13.2 lbs. (6 kg)
Dimensions (WxHxD): 17.3 in. x 2.4 in. x 15.4 in. (440 x 60 x 390mm)
Kristian Nilsson
Hej Magnus!
Tack för ditt svar, jag var nog lite otydlig, men jag menade minst 8 mick-kanaler, har ändrat det i texten nu.
Mvh
Kristian
Rolf Sirak
Inlägg av Rolf Sirak »
Hejsan Kristian...
Har tidigare genom åren haft Soundcraft rack mixrar och
när det blev dags för byte blev det för första gången en
Yamaha.
MGP16 är jag enormt nöjd med och den har riktigt bra filter
o mic preamps. 2 fx gör saker enklare oxå.
Kan man leva med 2 aux så tycker jag denna är en
riktig " swissknife " för alla småjobb där det skall gå
undan o låta bra..
lev å må
häls riffo
Lasse Johansson
Inlägg av Lasse Johansson »
Hej !
Soundcraft Delta SR
8 mic
4 sub
Fristående psu.
Bra skick.
Hör av dig om det kan vara av intresse.
Soundqraft Venue 2 med theater moduler
Det är en 20ram ( typ 16 kanaler)
Finns dessa moduler
16st mono
4st Stereo
4st Sub med retur
4st Sub med EQ
Alla moduler ingår vid affär, då kan man skräddar sy sin egen mix
Kristian Nilsson
Tack för era svar!
Riffo, jag har ett Yamaha MGP32X och det fungerar bra för pengarna. Upplever du att Yamahas modeller låter bättre än Soundcrafts motsvarande?
Jag har kikat på de mindre modellerna men de ligger lite över den tänkta budgeten i detta fallet.
Lasse & Nicke, de kan vara intressanta, men jag behöver en prisindikation.
Mvh
Kristian
jag skulle satsa på soundcraft eller A/H
nått i stil med en mixwissard
om man inte ska ta en soundcraft SiEx av lämplig storlek inte det billigaste men o så kompitent
och änkel
Lasse Johansson
Kristian: du får bjuda något om det är av intresse, PM:a mig i så fall.
/ Lasse
Johan Holmqvist
Inlägg av Johan Holmqvist »
Har en AH Mixwizzard 16:2
16 mono, 4-bands EQ, 2 svepbara, 6 AUX, inbyggd effektenhet
3500:- inkl. case
2500:- utan case
Kristian Nilsson
Då var detta löst i form av en mixwizard!
Tack till Johan Teknik:)
/Kristian
