Snygg moving-headeffekt med allt man vill ha i en enda enhet? Kolla in Youtube filmen här under
Om möjligt lite klen för större jobb med 2R discharge 135W, Lumen: 3900 LUX?
Någon som köpt eller sett dom live?
Blir mer och mer imponerad av Adj som tar fram produkt efter produkt som man verkligen vill ha för vettig peng och som framförallt har bra kvalité!
http://www.youtube.com/watch?v=oljZROKKrp0" onclick="window.open(this.href);return false;
http://www.thomann.de/se/american_dj_vi ... rid_2r.htm" onclick="window.open(this.href);return false;
Specifications:
• Compact high output moving head powered with a bright Philips® Platinum MSD 2R source
• 3 Operational modes: DMX controller, Master/Slave & Sound Active
• 3 DMX Channel modes (12, 10 or 16 Ch.)
• 7 Built-in programs that be used by a DMX controller.
• 13 colors + white, with two direction rainbow effect
• 14 Fixed Gobo Patterns + Spot
• Independent gobo and color wheels
• Gobo scroll mode
• Auto X-Y repositioning
• 6-Button menu system LED color display making it easy to navigate
• Display can be changed 180° reverse to fit different installation positions
• Gobo, Shake and indexing
• 8-Facet Prism
• Frost Filter
• 16 Gobo / Prism macros
• 540°/630° pan / 270° tilt (8-bit)
• 16-bit fine pan/tilt control
• Shutter: Pulse effect; random strobe slow to fast
• Electronic Dimming: 0% - 100%
• Fan Cooled
• Stepper motors with micro stepping
• Power consumption: 210W
• 3-pin XLR In/Out
• Multi-voltage Operation: 100-240V, 50Hz/60Hz
• Lamp: Philips® MSD Platinum 2R discharge 135W, 8.000°K – 6.000 hr. long life
• Dimensions (LxWxH): 16.75” x 12.5” x 9.25”/ 420 x 306 x 289mm
• Weight: 23 lbs. / 10 kgs
American DJ Vizi Beam Hybrid 2R
- Svante Gustafsson
