4 st the winner II scanners i dubbelcase. I perfekt skick, knappt använda.
1 st IMG Stageline Scan-25 (samma modell som "the winner") med sprucken spegel utan case
4500:-
Specifikationer
5 DMX control functions: (channel 1: strobe, channel 2: gobo, channel 3: colour, channel 4: pan, channel 5: tilt)
Music-controlled via integrated microphone
Master/slave mode with automatic run of programme
Horizontal resolution and vertical resolution: 255 steps each
Mirror is controlled via step motor
Gobo wheel with 14 gobos plus spot and shutter, colour wheel with 11 colours plus white
Matching halogen lamp (1 x 24V/250W/GX5.3) is available as an accessory and is not supplied with the unit, please order matching halogen lamp (HLG-24/250MRL) together with this unit
Power supply: 230V/50Hz/300VA
Dimensions: 20x14x50cm
Weight: 10kg
5 st Scanners i dubbelcase (nu 4500:-)
Emil Elmqvist
- Presentation: Svensk distributör av Nova acoustics
https://www.novacoustic.de/ - Ort: Sundsvall
Elmqvist Entertainment
Sundsvall
072-183 19 41
Sundsvall
072-183 19 41
Emil Elmqvist
Re: Scanners i dubbelcase(sänkt pris)
Sänkt pris!!
Sundsvall
072-183 19 41
Sundsvall
072-183 19 41
Emil Elmqvist
Re: 5 st Scanners i dubbelcase (sänkt pris 5500:-)
Sänkt pris igen, står bara och tar plats
Sundsvall
072-183 19 41
Sundsvall
072-183 19 41
Emil Elmqvist
Re: 5 st Scanners i dubbelcase (nu 4500:-)
Åter igen sänkt pris!
Sundsvall
072-183 19 41
Sundsvall
072-183 19 41
