linux hjälp
linux hjälp
nån som kan linux?
hur montar jag flera usb diskar?
How To Use a USB Drive For The VortexBox Media Library
Here are instructions for using a USB drive for your VortexBox media library:
1. Remove all other USB drives (e.g. a backup drive) from your VB. Plug the desired USB drive into your VB.
2. Login to your VB; see Login.
3. Find the device name of the USB drive. Enter
cat /etc/vortexbox/CurrentUsbDrive.txt
On a VB with one internal hard drive, this usually shows /dev/sdb.
4. Mount the drive. Enter
umount /storage
mount /dev/sdb1 /storage
Use the device name from step 3 with a "1" appended in the above command if it's not /dev/sdb.
5. If this works, then automount the drive at boot time. Edit /etc/fstab. Enter
nano /etc/fstab
6. Remove any line that currently mounts /storage. This line may look like
/dev/mapper/VolGroup-lv_storage /storage ext4 defaults 1 2
7. Add the line
/dev/sdb1 /storage ntfs defaults 0 0
Use the correct device name if it's not /dev/sdb1. This presumes the drive has a NTFS filesystem on it. If not, use the correct filesystem type in the above line.
8. Write the file (control-o) and quit (control-x).
9. Test the /etc/fstab entry by entering
umount /storage
mount -a
This should mount the USB drive at /storage.
10. If step 9 is successful, the USB drive will be automounted at /storage when the VB reboots.
11. If you want the proper drive to be automounted regardless of the device name, enter the command
blkid /dev/sdb1
Use the correct device name in the above command if it's not /dev/sdb1.
On my VortexBox, this returns
/dev/sdb1: UUID="725A66165AF23401" TYPE="ntfs"
12. You can then change the step 7 line in /etc/fstab to
UUID="725A66165AF23401" /storage ntfs defaults 0 0
Use the UUID returned by the blkid command on your system.
umount /storage
nano /etc/fstab
7. Add the line
umount /storage
mount -a
blkid /dev/sdb1
- Svante Gustafsson
Re: linux hjälp
Kolla på http://www.sweclockers.com" onclick="window.open(this.href);return false; eller liknande.. är nog ett mycket mer passande forum för din fråga
Re: linux hjälp
jo är inte medläm där och att jag tror att det finns ett helt gäng här som kan linux
- Anton Gildebrand
Re: linux hjälp
Kan säkert hjälpa dig om du kan berätta vad problemet är.
Re: linux hjälp
jo jag har flera usb hårddiskar som jag vill ansluta till en nas (gammal bärbar = liten hårddisk)
och jag vill då sen komma åt dom i programmet
men i instruktionen så ser det ut att bara vara för 1 hårdisk
hur gör man för att monta flera
- Anton Gildebrand
- Anton Gildebrand
Re: linux hjälp
Om du kopplar in den andra disken och skriver "mount", vad får du ut då?
Re: linux hjälp
massa text
[vortexbox.localdomain ~]# mount
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
devtmpfs on /dev type devtmpfs (rw,nosuid,size=603072k,nr_inodes=150768,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
/dev/mapper/VolGroup-lv_root on / type ext4 (rw,relatime,data=ordered)
tmpfs on /sys/fs/cgroup type tmpfs (rw,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpuacct,cpu)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/net_cls type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=24,pgrp=1,timeout=300,minproto=5,maxproto=5,direct)
configfs on /sys/kernel/config type configfs (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
mqueue on /dev/mqueue type mqueue (rw,relatime)
securityfs on /sys/kernel/security type securityfs (rw,relatime)
tmpfs on /media type tmpfs (rw,nosuid,nodev,noexec,relatime,mode=755)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime)
sunrpc on /proc/fs/nfsd type nfsd (rw,relatime)
/dev/sda2 on /boot type ext4 (rw,relatime,data=ordered)
/dev/mapper/VolGroup-lv_storage on /storage type ext4 (rw,relatime,data=ordered)
Re: linux hjälp
har lyckat monta 1 disk men inge fler hur gör jag
tänkte om man skapar en mapp med /diskb i slutet men det ressulterade bara i det här
[vortexbox.localdomain ~]# mount /dev/sdb1 /storage/diskb
Mount is denied because the NTFS volume is already exclusively opened.
The volume may be already mounted, or another software may use it which
could be identified for example by the help of the 'fuser' command.
Re: linux hjälp
fick just fram detta
och det verkar inte stämmaMonteringspunkt Typ Partition Kapacitetsutnyttjande Ledigt Använt Storlek
/ ext4 /dev/mapper/VolGroup-lv_root 9% (1%) 16.44 GB 1.81 GB 19.22 GB
/boot ext4 /dev/sda2 7% (1%) 426.46 MB 32.76 MB 484.22 MB
/storage fuseblk /dev/sdb1 99% (1%) 9.87 GB 921.65 GB 931.51 GB
/storage fuseblk /dev/sdc1 99% (1%) 9.87 GB 921.65 GB 931.51 GB
/storage fuseblk /dev/sdd1 99% 9.87 GB 921.65 GB 931.51 GB
/dev devtmpfs devtmpfs 0% (1%) 588.94 MB 0.00 kB 588.94 MB
/dev/shm tmpfs tmpfs 0% (5%) 596.30 MB 0.00 kB 596.30 MB
/media tmpfs tmpfs 0% (1%) 596.30 MB 0.00 kB 596.30 MB
/sys/fs/cgroup tmpfs tmpfs 0% (1%) 596.30 MB 0.00 kB 596.30 MB
/run tmpfs tmpfs 0% (1%) 595.68 MB 632.00 kB 596.30 MB
Totalt : 98% 47.61 GB 2766.78 GB 2815.39 GB
