Pearl PROBLEM just NU
Har gig om ca 40min och pearl bordet har fått frispel
Håller typ att optimera minnet, hållet på typ i 15 min nu
Någon som kan ringa mig eller jag ringa
:roll: Det är lite av panik
Peter Jönköping Hallin
Inlägg av Peter Jönköping Hallin »
Resetknappen på baksidan har du testat den?
Har du showen sparad på disk?
Ring Johan Friberg, nr finns på Bellalites hemsida.
Jag har tetat det.....då står det ENERGISING PEARL
Har du allt sparat på disk?
Isåfall kan du testa att göra en "Hardware wipeall" genom att lyfta på locket och bygla "wipeall link" bygeln som finns på moderkortet.
Jag klipper in den info som finns i manualen:
You can do a complete factory reset by fitting a link on the board. You
should obviously save any show data that you want to keep. It may
also be advisable to have a backup of the system software (AVOS
option D) before you do this… just in case.
1> Disconnect the Pearl from the mains.
2> Undo the half-turn fasteners on the rear edge of the console, and
lift the fader section of the console.
3> Fit the Wipeall link. On Borris 3 motherboards this is at the
bottom right of the board near the 4-digit display. On older
motherboards it is located on the main PCB near the large square
processor. It’s labelled on the PCB legend. A link is provided fitted
to one of the pins. Fit the link so it connects the two pins.
4> Close the console (don’t fasten it), then turn on the power.
5> The console will power up in the AVOS menu. Select option A
“Start the System”. (do not select any other option when the
Wipeall link is fitted).
6> Turn off the Pearl, open it and remove the Wipeall link (fit to one
of the pins only). If you forget this, the console will do a Wipeall
every time you turn it on!
7> Close the console and refasten it.
If you do the above then restart the console without selecting “Start
the System”, you may not be able to get the console to run. Use the
following procedure to start the console. This procedure is also another
way to get into AVOS mode.
1> Turn off the console and open as described above.
2> Fit the AVOS link. On Borris 3 motherboards this is in the bottom
right corner by the 4-digit display. On earlier boards it is located
near the chip labelled “PASHA”. It is in a row of 8 jumpers, the
AVOS link is the one nearest the back of the console. A link is
provided fitted to one of the pins. Fit the link so it connects the
two pins.
3> Close the console (don’t fasten it), then turn on the power.
4> The console will power up in the AVOS menu.
5> Select A [Start the system]. Do not select any other option.
6> Turn off the Pearl, open it and remove the AVOS link (fit to one of
the pins only).
VILKEN GREJ!!!!!!!!
Johan Friberg Svarade och han hjälpte mig....den var UNDERBART
En tvåhands fattning och trycka på olika ADD knappar
Tack godegud....det blir SHOW :-)
Tusen tack Peter för din info
Vi började med att göra en mjukvare restore
Men tack än en gång PETER....du är KUNG
Andreas Staglianó
Inlägg av Andreas Staglianó »
Där ser man en föredel med Bellalite vs. Thomann,Steinigke mfl.
Johannes Tegern
Inlägg av Johannes Tegern »
Jag håller helt med. Jag har fått denna grymma support av både Bella, Martin, Arva, Bose och Yamaha! Dom hjälper en direkt i mån av tid när man har problem.
Fredrik Nilsson
Inlägg av Fredrik Nilsson »
....jag lägger till Interlite på den listan
Work sucks, send me on tour!
Andreas Staglianó
Givet, en eloge till herr Noren också.
