Teknikertest...
Teknikertest...
Sound Engineer Test
Golden Ears!
You scored 87 aptitude and 73 hearing! 11 wank.
You're a master. You understand the method, the madness, the magic. People go to gigs and don't even realise that you exist. The sound is so flawless, there is no hint of human hands doing the hard work at the back of the room.
Golden Ears!
Tomas Nordström
- Presentation: Fd anställd numera frilanstekniker när jag känner för det.
Golden Ears!
You scored 86 aptitude and 75 hearing! 10 wank.
Tomas Nordström
Jerker Björn
Sound Engineer
You scored 82 aptitude and 61 hearing! 7 wank.
You've got the nouse, you have the passion, and you've even managed to look after your hearing pretty well. You're the man, quite simply. You know your way around a console, around a venue, and around the scene. Awesome.
^^ Inte såå långt efter med andra ord? =D
- Magnus Söderman
The Audiophile
You scored 75 aptitude and 68 hearing! 10 wank
You certainly know a lot about audio, and you've looked after your ears well. You're in this for the music and the love, not to be some kind of hotshot. Good on you.
Inte sååå illa efter att ha gjort nästan bara monitor i 10 år .. *S*
Magnus Söderman, envis men snäll
I want everything louder than everything else (Ian Gillan, Deep Purple)
- Tobias Walka
Jocke Hammar
David Göransson
Niklas Olsson
Sound Engineer
You scored 80 aptitude and 62 hearing! 18 wank.
You know what you're on about, and you've guarded your greatest assets: your ears. You work in the industry, care about the industry, and live to enhance other peoples' talents. Without you the entertainment industry would fall apart.
Och en annan ska vara ljustekniker ... :S
- Jan-Olof Carlsson
Samuel Nielsen
- Presentation: Samuel Nielsen, verksam sedan -98 inom ljudbranschen!
- Håkan Petersson
Sound Engineer
You scored 83 aptitude and 66 hearing! 12 wank.
Mix Master
Congratulations! You have recieved the Mix Master award. Somehow your keen sense of the obvioius combined with an in depth awareness of the nuances of the auditory profession has allowed you to navigate your way to being a Mix Master. You are on the right track and somehow figured out that all you hear is not to be believed. Good luck and congratulations!
Mix Master
Mikael Heurlin
- Presentation: Egen företagare inom anläggnings branschen med en fot i ljud träsket också.
- Christer Löfgren
- Presentation: Företagare sedan 1998 driver Sveriges närmaste ljud/ljusuthyrning
Företaget lades ner 2013-01-01 - Ort: Enköping
- Daniel Hedman
Tommy Lindroos
Your Score: Golden Ears!
You scored 85 aptitude and 69 hearing! 25 wank.
Jacob Thulesius
- Presentation: Fram tills nu har jag frilansat som musiker & ljudtekniker, jobbat som instrumentlärare, Apple-försäljare och drivit egen konsultfirma. Nu är siktet inställt på juridiken men vem vet vad som händer i framtiden...
Sound Engineer
You scored 74 aptitude and 67 hearing! 10 wank.
på den andra.
på den andra.
- Hans Ekdahl
Henrik Malmberg
Your Score: Golden Ears!You scored 88 aptitude and 73 hearing! 13 wank.
My test tracked 3 variables How you compared to other people your age and gender:
You scored higher than 95% on aptitude
You scored higher than 80% on hearing
You scored higher than 33% on wank factor
Hmm, oroväckande högt på wank factor...
- Daniel Samuelsson
- Presentation: Intresserad utav branchen. Arbetar med offentlig belysning.
You scored 59 aptitude and 78 hearing! 25 wank.
You scored higher than 18% on aptitude
You scored higher than 94% on hearing
You scored higher than 62% on wank factor
Andreas Hårsmar
- Presentation: Jobbar på Nöjesbyrån i karlskoga som ljudtekniker.
