Hej
Nu kan den som vill, köpa DVI Parrots av mig.
DVI PARROT är en mycket fiffig lite sak för att programmera EDID.
Skicka PM eller hör av er på 0707 969696, eller dra ett mail till morgan@brownsblend.com
Hardware
Rugged, compact device - only 28mm cable insertion / panel depth.
Dual-link DVI-I compatible for high bandwidth digital and analog functionality.
DVI powered for spoofing & capture, USB powered for training - no additional PSU required.
Compatible with VESA EDID 1.3 and EDID Extensions EIA/CEA-861 (HDTV support etc.).
Accessible 'mode' button and RGB status LED provide basic hardware control.
Press to switch between EDID spoofing and pass-through
Press and hold to capture EDID of connected monitor or device
Elegant and cost-effective solution to a significant problem.
Trainer Software
Mac OS X, Windows XP (32bit), Windows Vista (32bit), Windows 7 (32bit).
Free to download.
Provides precise control of EDID settings via USB.
Standard EDID library supplied or users can capture, edit or create their own from scratch.
Libraries can be imported and exported to share and manage EDID settings.
Multiple Parrots supported for devices with multiple outputs.
API provided for seamless third-party software integration.
Mer info finns på http://www.dviparrot.com/" onclick="window.open(this.href);return false;
Vänligen Morgan Brown
DVI PARROT
Morgan Brown
