Teknikertest...
Fabian Ebbesson
Inlägg av Fabian Ebbesson »
95% on aptitude
93% on hearing
8% on wank factor
Efter att ha vart student på porthälla gymnasium i snart ett år =)
Adam Ander
Inlägg av Adam Ander »
Golden ears!
You scored 90 aptitude and 68 hearing! 7 wank.
Alltid nåt :D
Hello, my name is Ninja.
Johan Billow
Presentation: Jobbar med ljud, ljus och webbproduktion. Håller dessutom på med att ta busskort - har alltid viljat ha det.
Massor av intressen också...
Inlägg av Johan Billow »
You scored 84 aptitude and 60 hearing! 36 wank.
You've got the nouse, you have the passion, and you've even managed to look after your hearing pretty well. You're the man, quite simply. You know your way around a console, around a venue, and around the scene. Awesome.
...och jag som bara jobbar med ljus, nästan...
Daniel Noise Johansson
Inlägg av Daniel Noise Johansson »
Golden Ears!
You scored 83 aptitude and 76 hearing! 17 wank.
You're a master. You understand the method, the madness, the magic. People go to gigs and don't even realise that you exist. The sound is so flawless, there is no hint of human hands doing the hard work at the back of the room.
Fan av 3Fas feat Nollan!
kul test
Your result for The Could You Be A Sound Engineer Test ...
Golden Ears!
You scored 82 aptitude and 73 hearing! 14 wank.
Rate my test!
* Currently quiz/5 Stars.
* 1
* 2
* 3
* 4
* 5
* Can't tell
* click away
Compared to other takers
* 86/100 You scored 82% on aptitude, higher than 86% of your peers.
* 88/100 You scored 73% on hearing, higher than 88% of your peers.
* 30/100 You scored 14% on wank factor, higher than 30% of your peers.
Göran Blomgren
Inlägg av Göran Blomgren »
